Thread: Bic DDP
Old 01-16-2008, 02:18 PM   #2
Chambers
Chambers's Avatar
Well I can't help you with the exhaust but I can give you some advice about the emissions. If you have a good cat, 02 sensor, and not running to rich, then you should pass emissions, but I don't know how strict they are in your state. As for the visual inspection, as long as you don't have a test pipe in they should be able to see the cat and pass you on that. Good luck!
"Stuck in the 80's"
