it will probable be hard since auto transmission will always be changing gears on you depending on how much you put on the gas. example here: 'you are going 20 with auto with gas pushed down 1/2 way, it will be in 2nd gear. if you then floor it, it will shift down to 1st to give you max torque and hp. if you let off the gas completely, it will shift to 3rd to let you cruise at 1000 to 1500 rpm. manual gives you more control over your car
 zoom zoom!
