does it studder kinda bad when in the boost, you can check the throttle body to 3000 pipe boot, there are verious hoses to check. but i had the same problem in my 88 turbo and you know what it was number 1 and 2 cylinders where seeping, pull your plugs out and take a nice brite light and look down into the head if you see anti and oil theres your problem. if not i would have to say a hose then , cause if your cat was plugged it would not go over 45 mph
save a tree eat a beaver........
