Well, ive checked the High Beam fuses. They are the normal clear plastic fuses, and they work just fine. Just my low or regular beam lights aren't working. There is a big fuse, different than the others, that says "HEAD" on the diagram. I'm wondering if thats it??? Sounds like a pretty easy trial and error run in any case. Thanks for the help!
One more question: Just had a bunch of work done to my Supra. New engine gasket kit, all new seals, timing belt, clutch, hoses, belts, water pump, tires, struts, and a few other minor things. Its running great, only its not starting as well as it did. Granted, its really cold here right now, but it was starting quickly before I had the work done, now i have to pump the gas, and give it about 6-7 tries to get it started.
Any idea what I can do to remedy this? I can't be wondering if my car will start on a daily basis, and this can't be good for the starter or the battery.
Any help would be great!
Thanks!
Taylor
1985 Toyota Supra 5MGE DOHC 2.8L 12v L6
