Drive it.
Have a mechanic you trust check it out, top and bottom.
Have your mechanic trest drive it.
Have your mechanic do a block test and a compression test on it.
There is a thread around here about what to look for in a used car, find it and do all that stuff.
Extra parts are good if you have a place to store them, and if you have the tools and ability to replace them, otherwise they end up just taking up space, but you can sell them and try to make some of your money back.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
