Old 01-18-2008, 10:44 PM   #12
btwilson86
Super Moderator
btwilson86's Avatar
Using stock gauges probably won't work, due to differences in resistance values/wiring between gauges and sensors on the new motor. Would probably have to go with after market gauges that are wired independently. The ECU is only really needed with fuel injection/emissions controls, so if you're swapping in a carburetted 350, you're not gonna be able to pass emissions, and therefore don't need to worry about controlling them.
Unless you want to do your part in protecting the planet.
Then you should get a POS Prius.
