pending on how long the gas has been in there and how much gas there sometimes additives wont work at all, i bought a crx once that was sitting with a little under 1/2 a tank of gas in it, we had put like a can of seafoam into it to clear it up but it didnt work there was so much rust in the tank it wouldnt cure it, and it ended up destroying the head from all the rust, your best bet is to play it safe and pull the tank and look inside if its full of rust replace the tank with either a new on or one from a yard or look on ebay, and youll need to put in a diffrent pump also all that rust has destroyed the pump also and changed the filter to, trust me play it safe i went threw 2 heads on the crx and couldnt firure out why until i took of the fuel filter and the gas looked like tea. this is probley why the car runs like crap, almost garentty it, so quit starting it and letting it run trying to figure it out, pull the tank.
save a tree eat a beaver........
