Which fuse is the one that keeps blowing up?
You probably have a shorted light bulb, or corroded ground somewhere in that circuit. If its the taillights, and you have an aftermarket stereo, its probably the wire for the interior light that goes to the stereo that is shorted out.
Why don't your turn signals work? Is that also a fuse problem, or switch, or hazard switch or what? It could be related and help you find your other problem, or it could be competely different.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
