Old 01-22-2008, 04:09 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
TPS= Throttle Position Sensor
AFM= Air Flow Meter (aka Mass Air Flow Sensor)
ISC= Idle Speed Control
On the top of your engine, at the throttle body (where the cable from the driver's side of the car links to the engine), there is a sensor with a plug coming out of it. The plug is typically black, and has 4 wires going into it. That's your TPS and plug. Make sure it is connected well.
At the top, front of your intake manifold near the crankcase oil cap is another sensor. I can't really describe it very well, but it has a 6 wire plug coming out of it. That's your ISC and plug. Makes sure that is connected well.
Off of the engine at the passenger side of the car is your intake piping. At the end farthest from the engine, right before your air filter, there's a bulky box-looking thing that the air goes through in the piping. That's your AFM. Make sure the plug on that are also connected well.
Just thought I would simplify what was afore stated for you, although I don't believe I can contribute any additional advice.
