i tried starter-fluid at one point and had a fireball come out of the intake, so i am getting spark. also, i have new spark plugs, wires, rotor, and distributor cap on it. i've installed a new Walbro fuel pump and it is working. when i tried starting the car after installing the fuel pump, i heard a faint pop. kinda like pressure being quickly released. that's when i found that the #2 injector was leaking fuel (bad o-ring). the engine is a professionally rebuilt 7M-GE. the engine came already timed with a timing belt on it and it has a 3 year warranty. i'm assuming the compression and timing are fine.
