Is the ecu grounded?
The two white around black wires and the brown one next to them? And the case too. You may have a problem like mine was, when I grounded the case of my ecu, it started right up.
If you have a stethscope listen to the injectors, they should click.
You can also use a long screwdriver, just put your ear on the handle.
Or get a noid light and hook it up to the injector plug to see if they are getting grounded by the ecu.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
