The temps on the page say "on" at 212°F, and "off" at 203°F.
It doesn't matter what engine you have, just that the only supra that had the electric fan from the factory was the auto tranny turbo car. (Engine coolant temp fan.)
The 104-140° is for a different water temp sensor, I think it has something to do with the heater. I just can't figure out exactly what.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
