I would say yes and no, 1700 isnt a bad price also its a hard top very rare. It has had alot of money put into it, but im not so sure about the engine setup. I also bought an NA but mine was fully converted over with a JDM GTE. The only real problem you need to think about is the trans and the rear end. To convert it over with all new parts its like $10,000. That is only if you want a 313 rear end the rear on an NA is around a 4.10 if you know anything about rear ends. This means that with the NA rear your looking at being around 4000 RPM at 80 MPH. I dont like this set up so im installing the 6 speed and TT rear end. So it all depends on what you want, you could even pick up a GTE engine for about 3-4 thousand. Or look into getting a head and intake just some things to think about.
