1jz DP
eBay Motors: 1JZ 2JZ 1JZGTE 2JZGTE V-Band Turbo 3" Downpipe Supra (item 330206583758 end time Feb-01-08 19:07:13 PST)
do any of you think that this DP will work with my 7MGTE, i have gotten a new turbo with the v-band and i need a DP that has a Wideband plus our stock heated 02 bunges. so i was wondering if it would clear the firewall?
7MGTE - 500hp  never dyno'd
fidenza cam gears
