Not too hot, the gas engines run much hotter then a diesel.
Also at 15psi pressure in the cooling system, it can go up to 230° before boiling, each pound of pressure adds 1 degree to the boiling point. That is also tested at the thermostat housing on the outlet side of the engine, where the coolant is the hottest.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
