OOPS!
a540e is newer, a340e is correct.
Thanks for clearing that up.
Ray.
p.s. why would you want a w58 on a 2jz? That seems like it would be pretty unreliable. From what I've heard the w58 won't even hold up to the 7mgte.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
