Too high boost pressure due to a disabled waste gate could definetly cause this code. I would reset and not worry about it, unless it comes back, then take out your spacers and see if it comes back a third time, if it does, then worry about it.
Until then have fun with the 12psi!
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
