Batt.
Hey,
595 CCA, (cold crank Amps) this is more than enough if in fact thats what your getting from your batt, i'm running a 3.0 turbo on 400 cca batt which is a little lower than what it should be.
You may have a short in your batt caused by buckled plates in a cell reducing your load capacity.
check your grounding and borrowed batt. to try
ta stewie
