Old 02-24-2008, 07:49 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Easy Way to Change Air Filter
Has anyone figured out a simple way to change the stock air filter on a turbo? Seems the only way is to disconnect all the hoses starting at the turbo inlet, and work toward the front. Too bad it can't be done by removing one simple wingnut.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
