Thanks for the replies. The stock setup seems to be a cold air intake, because the front plastic filter assembly picks up air from in front of the hot engine compartment. What aftermarket setup would replace that? Is a K&N unit easier to clean?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
