to get a jz manifold to fit you will either need to make a custom lower piece or an adaptor. an adaptor would be cheaper by far, but the flow wont be as great. i really dont think that should be to big a concern on a na though. you still may need to get some custom work done to the manifold to make sure you can still get all the ports you need. as for tb's, im not to sure. maybe just the stock jz tb? idk
