Tokico Illumina II-TEMS worth it?
Is it worth it to get the Tokico Illumina II's? I have a TEMS MKIII and the stock struts are starting to fail (given away by the rediculous amount of bouncing), and I was wondering if the Tokico Illumina II's were worth it or if I should just stick to the stock struts. What are the advantages of the Tokicos? and what springs would go good with them?
Thanks in advance!
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
