yes, it is easir, basically just a pull on and put on situation, however I would suggest if your going to put the K&N on is find a heat shield as putting on the K&N will pull the air filter into the engine compartment. You can actually make a heat shield but they are easy to find just google it. K&N doesnt make a full CAI intake for our cars, I had to actually go custom on mine. Went and had a pipe made that goes to just before where the stock air filter connects to the hole into the bumper and then put the K&N inside of the bumper, good air flow and protects it from water, rain etc.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
