Like evryone has pretty much said back pressure is not needed and turbos perform better when it has less. I would suggest leaving a slight amount but not too much is needed definitly not as muchas the N/A version.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
