radiator is plastic on the top and is barely seeping can't say i have seen a plastic radiator either. I dont have a lot of oil in the intake hoses but it is coated. Wondering if i have some time or will it be going soon. can't get car to boost past 6lbs . changed plugs today and they all looked good but the #5 plug has less wear the insulator under the electrode was still white were the others were brown maybe this cylinder is not firing correctly how do you check the coil packs? thanks
