Old 03-10-2008, 05:15 AM   #16
supramacist
supramacist's Avatar
Bogged down as in not reving fully.
Feeling restrained.
I sprayed starting fluid around all the vac lines and not even a shimmy from the engine.
I know my afm connect isn't plugging very well.
I wonder if you can hot wire that thing straight through?
I keep throwing code 31 which is afm ecu. I trouble shot and it said if those were fine to correct running lean. I pulled 6 and that's not the case.
The afm plug being faulty would make it throw a code. I hope.
