Old 03-11-2008, 02:57 AM   #1
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
Default my 89 turbo auto problems
okay, my car needs some help that obviously cant come from me so i thought you guys might wanna throw in your 2 cents..
first off my car has a hard start problem, it takes 3 or 4 turns for it to actually start and when it does it idles like at 500rpm. as the motor runs for a while idle will raise to 1000rpm which is what its supposed to be.. so its what i like to call morning sickness. but ive been shooting in the dark trying to fix this bitch i replaced the ISC, adjusted the tps (got a code 51 as well but didn't go away when i adjusted it according to trsm) and the cold start injectors resistance was fine. dont really know what else to do
i also have a code 22.. i've replaced almost every sensor on the thermostat housing and i replaced the overflow sensor.
lastly i was going to see if anybody had an extra accordian hose laying around (hose between MAF and turbo inlet with stubs for bov, p/s, pcv)
-and the wiring harness is a known good so shorts and opens are most likely not the problem
thanks for the help.. need to get this bitch legit so i can throw the r154 in there
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
