Originally Posted by marc
my car currently does not run, its an 88 turbo. when i push the clutch in as to start it, it does not return to the up position. the clutch pedal just sticks to the floor. how should i go about fixing this? low fluid? some sort of spring problem?
same thing happened to me. took it to the shop and they said the master cylinder hose was bleeding. replaced it and now it's back up and running.
