BTW I believe the redline for the R154 is higher than the W series tranny, I could be wrong though. Also our gross wieghtage for turbos is roughly 4400 Lbs., or 2000 Kilos. I know the redline in my R154 turbo is 7500 RPM. However for your needs your contridicting yourself. You want a lighter wieght tranny that has higher RPM then you are looking at the wrong two series trannies. Either your going to get higher RPM from the heavier tranny or lower redline from the lighter one. I would suggest getting a diffrent series than the R or W. Sry bro. Good luck with your project
Oh and btw if yoru doing what I think your doing the W58 wont do, your going to need a stronger tranny, plus you have other factors to consider here, flywheel, clutches, etc. its not just reliant on the tranny.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
