I don't think you can get any CEL codes since it won't start... You said you smell gas, so I would think it would have to do with a lack of spark. Check 15 Amp EFI fuse in fuse block under hood is in good shape... Since you said you just got it, you should probably give it a tune-up (which might in turn help fix your problem). Do some simple stuff like replace the spark plug wires and plugs, things like that. You might also want to check to make sure your coil packs are properly grounded.
Hope some of this helps, I'm sure some people more knowledgeable on Turbo Supras will chime in here soon.
