Originally Posted by supramacist
That being said. The r series tranny is what you want.
The redline is at 6k on the w series.
This is the only reply that even addressed shift points. It isnt very descriptive. Ive never heard anybody describe a redline when describing anything related to a tranny, but are you saying that the w series will only shift up to 6k rpm or are you saying that the vehicle that the tranny came out of has a redline of 6k?
You should expect 7k rpms to be the max revs for safety on these trannies.
And 7k may be pushing it. But if you set it up right.
max revs for safety leads me to believe that you are trying to say if you try to go above 7k it will explode. I doubt this is the case, but maybe you can reword what you are trying to say so that it makes sense.
Also, nobody has mentioned anything about upgrades to raise shift points.
Its kinda like pulling teeth around here. My questions arent very complicated.
1.How high will these trannys shift?
2.Are there any upgrades to raise the answer to question #1?
Very simple questions.
