Originally Posted by CyFi6
depending on the engine you can start pinging if you remove the egr from the raised combustion chamber temps
Well I believ he is using the 7M-GTE, or are you referring to the age, wear and tear factors. I belive retarding the timing should help with that problem..or is
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
