Thread: please help
Old 03-17-2008, 02:00 AM   #2
Supra Goddess
Supra Goddess's Avatar
Supra Goddess is on a distinguished road
Check your fuses. The ones in the fuse box near the battery AND the fuses in the drivers side kick panel. There's an ignition fuse in the kick panel that will make it not start. Also, make sure the ignitor is grounded properly and the other grounds are good too (ground from engine block to battery, ground from transmission to chassis, ground from back of head to chassis, ground from the wiring harness to a bolt on the intake manifold...it's on the underside of the manifold)
Supra Goddess is offline   Reply With Quote
