Supra Problem!!
When i start the car cold, it starts like a champ. Runs great, idles good, when cold idles at 1,200rpm when warm 700rpm. The only problem i'm having is after it's been running and i let it cool down then shut if off if i go to start it 15 minutes later it'll start then die, start then die, start than die, no matter what gas i give. Eventually i can keep it running by flooring the gas and it has a horrible misfire that clears up when i rev it high. I already change the spark plugs and wires. Runs really good otherwise.
Any help?
