I have issue with hot starts also, along with many others, although mine is not as bad as yours. From what i have read, the fuel in the rail gets so hot that it turns into vapor, and when you restart the car you are spraying out little liquid fuel.
My question is, is our fuel rail losing pressure when we turn the car off? There is supposed to be a good amount of pressure in the rail to keep fuel from boiling and doing this. Someone else needs to chime in.
