when the car is cold oil pressure should be around 40psi maybe a little bit higher.. and at idle it should be around 10-20 psi depending on the viscosity of the oil.. and if your doing 80 on the freeway oil should be close to 40
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
