7MGE is the N/A 7MGTE is the turbo version.
The clips will fit right up to the GTE as will the mounts. You will need to get a new ecu. as far as links google is an excellent resource (no i am not being a smartass). You will find most of your links for imported engines, etc.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
