Well having a air compressor will help with prepping everything. You can use the spray nozells to help remove dust and debre from the stuff you are painting.
I'm pretty sure you can get a air tool that is like a dremel for polishing, but for sanding, something like that which spins at high rpms is not so good for prep work of this sort, because it is real easy to take to much material off and you have a end result that looks bad. Good luck!
"Stuck in the 80's"
