Thread: which gasket?
Old 03-26-2008, 01:27 PM   #2
Chambers
Chambers's Avatar
I'm not sure about everything but I will tell you what I know, the thicker the gasket the lower compression will be. For a NA it wont really matter how thick, but I would go for a 1.2 or 2mm, because it will not see any boost, so you wont need a thicker gasket to hold it. Hope this helped.
"Stuck in the 80's"
