Thread: No Start Hot
Old 03-27-2008, 05:34 AM   #1
kwayne
kwayne is on a distinguished road
Default No Start Hot
I have an 87 7mgte. When cold, it starts and runs fine as long as the ignition is not turned off. Once it's turned off, it has to cool down before it will start again.
I have found two ways to start the car hot. It can be roll started, or it can be started by bypassing the efi main relay with a jumper wire. So far I have replaced the ignitor, ecu, fuel pump, fuel filter, cam position sensor and coil pack. All vacume line have been replaced and all leaking moulded hoses have been replaced.
Does anyone have any ideas?
kwayne is offline   Reply With Quote
