I've had similar problems, except it was with my sub system. I had it hot constantly, so I wired a switch up to the deck - Sub antenna to turn it off when I was done with it, seemed to fix the problem. If your battery is fine, it could be an ignition relay or main relay. Have you checked your fuses? It could also be that you need to replace your positive battery cable clamp. Cars suck like that, haha
Burzum - Die Liebe Nerpus
"I am a man and I hold in my hand my fate" - Quorthon
