Originally Posted by paulmicin
no. 1 cylinder has 50 psi while the rest are within spec. I poured some oil in no.1 and it jumped to 70 psi
20 psi is just around specs for the jump in psi with a wet test. Even brand new motors will jump considerably in compression when doing a wet test. I wouldn't say your rings are bad. Try a wet test in the other cylinders and see how much they jump up.
