Check the neutral switch. Its located on the transmission, close to the exhust pipes. The heat will cause it to fail, preventing the starter working. After it cools off, the car will start fine. Worst case, it can be bypassed but I don't recommend it. You lose the protection of not starting in gear and cruise control.
