Old 04-04-2008, 09:05 PM   #16
Bill UK
AEM EMS
Bill UK's Avatar
You could be in luck, whilst doing a big end repair a few years ago I removed the engine and tranny and took a few photo's, as you can see the fixing bolts go straight through (well the ones along the side do) You should be able to drill through your stripped threaded hole and use a longer bolt with a nut on the other side. I don’t have any images of the ends of the oil pan, so please check the holes out before drilling.
