Old 04-04-2008, 09:48 PM   #1
turbojuiced
turbojuiced is on a distinguished road
Default 89 7mg to 2jz turbo manual
First I would like to say hi im new here obviously. I did do a search on this particular build and already found some info. However, I do have some further questions regarding this particular build.
As the title says thats what I am looking to do. My idea is to buy a jdm already assembled 2jz turbo engine with the ecu and comeplete wire harness with the 6sp tranny already connected to it.
My questions are 1) does anyone know of anyone here who has done such a thing and if so can you point me to them 2)is there anything that I should know about this swap like any custom modifications needed? 3)and if anyone knows of any places I could get misc parts from for the manual conversion that would be cool
So far I have the following info from suprra grl via the sticky. I need the following parts for the manual swap (mind you the sticky was about a 7mg conversion to manual).
clutch pedal,brake pedal,clutch master cylinder, clutch slave cylinder, manual driveshafts for the 2jz tranny, shifter assembly, clutch kit/flywheel, clutch line between master and slave cylinder
If I am missing anything else please let me know thank you in advance
turbojuiced is offline   Reply With Quote
