04-05-2008, 11:51 AM
#1
Hot Start Problems!!
I have a 90 7mgte that will start from cold will restart straight away when hot but if left for a couple of minutes will not start until fully cold. There seems to be no signal to the injectors, no power to fuel pump but when bridged will run,all temp sensors work,cps works, even rewired the cps terminals, efi relay works, main circuit relay works.
Any suggestions?? please not the ecu!!
