The electronics in the Lexus meter do not work in the Supra. The stock electronics of the turbo Supra will bolt into the larger housing of the Leaxus air flow meter. You still need good electronics.
At this point you might as well try pulling the electronics out of the meter and VERY carefully cleaning them with brake cleaner. Don't use too much as it eats seals and plastics. There exists the possibility that the oils usually left behind by carb cleaner have just fogged the outside of the optical sensor. I'd spray it on cotton swabs and slowly clean it out by hand.
Please try to break your posts up into paragraphs.
Supramacist is (as his screen name suggests) thoroughly bull headed about some things... mainly anyone who wasn't born knowing everything about the Supra. I think he should chill out though... it's counter productive and annoying as hell. (HINT)
