Compression check question...
Hi!
I tried to check the cmpression of my 7M-GE...the gasket on this one is blown and I couldn't warm it up before the testing how the service manual says.
So it says 9kg/cm....when I added a bit of oil it was already 12kg/cm
The question is HOW BAD IS THIS ENGINE? Do I have to change the rings as well?
I appreciate any advice!!!
Thank you!
