Thread: 180 out?
Old 04-08-2008, 07:55 AM   #1
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
If you pull the plastic cover off that covers the cam gears you will see there are timing marks on the cam gears themselves. At TDC they should be pointing straight up. As far as sticking the distributor the way i have always done it is get it to TDC. Point the rotor a little before (to the left) of the no. 1 spot on the cap. When you put it in, the rotor will turn so it might take you a couple trys to get it just right. Hope this helps and anyone else correct me if i'm wrong.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
