Auto or Manual Box ? If its an auto you could have leak in the radiator between the coolant and the tyranny fluid cooler. An auto supra has a radiator made in two sections, the bottom section is an oil cooler for the tyranny fluid, whist the majority of the top part is for the engine coolant. Also; have you removed the engine oil filer cap to check for any white deposits of emulsified oil.
